jessielucyy
30 points
Posted on - 12/12/2012
I wanted to post images and received an error message. It says, “705 – UNABLE TO CONNECT TO SERVER”. I tried to post them again and again but failed.
If you have any idea for the error, please help me to get a remedy of this issue.
Thanks in advance for all solutions.
Hi there user:
I think the problem is with your local. It seems that you contracted with malware, so I would suggest you to run a full scan of antivirus and Kaspersky TDSSkiller.
But before you do that, you will need to verify your proxy server. Go to your explorer tools, and then click the Options. Now roll over your Network Connection and then test if the error is still there. If the error still persists, then I’m really sure it’s a malware. Run a full-scan and it’ll be fine afterwards.
Feel free to share your query to us.
Best regards,
