90 percent installation complete and System Showing Installation failed
I installed .Net Software that aborted leaving 90% installation completed. I tried to reinstall more than one time and nothing positive. The software DVD is fine because it’s installed perfectly other machine. I can install other software perfectly. I can't find a fix for this problem on the web. . How can I fix this problem? Thank You
Answered By 5 points N/A #172180
There are many reasons that this problem might occur. Please check them all.
First of all, make sure that a specific service runs perfectly.
1. From Start menu, type “services.msc” >> hit Enter.
2. Scroll down and find out “Windows Modules Installer”.
3. Double click on it make sure the followings are selected. If not, turn them according.
Startup type: Manual
Next, make sure that you’re trying to install the latest .NET Framework. Download .NET Framework 4.5.2. Then, try this installer.
.NET Framework requires the latest Visual C++ Redistributable installed. Download and install Visual C++ Redistributables.
Also, start an elevated Command Prompt, run “sfc /scannow” command and after completing, install .NET Framework.
