Hi! I just got myself a PSP, and I am still new to this gaming stuff. From past few days, I have been getting an error whenever I try to play any game. The message “Game could not be started (PSP error code 80020148)” displays and it takes me all the way back to the start menu. I don’t know how to fix it. Please help me. Thanks!
A 4-step Formula For PSP Error Code 80020148: A Complete Solution.
If you have a Sony PlayStation Portable and you want to play a game but this error code “80020148” keeps appearing, try this method. On your PSP, go to the “Recovery Menu”. To do this, turn off your Sony PlayStation Portable. Once it is turned off, press and hold the “R” button then turn on your PSP. Next, go to “Configuration”, “Use NO-UMD” then disable it.
After this, go back all the way to the main menu then go to “Advanced”, “Advanced Configuration” then disable every item. Try playing again and see if it works. If this doesn’t work, try updating your PSP. Go to PSP System Software Update then download the latest firmware. Follow the instructions on the page to update your Sony PlayStation Portable.
1....
