A Guide On How To Connect A Laptop To TV Wirelessly.
I want to showcase my desktop’s screen on my Smart TV. The television has a built-in Wi-Fi support. Now, how to connect a laptop to TV wirelessly?
Although the best way to connect a TV and computer remains via an HDMI port, certain good options for wireless connections are as mentioned below:
It is offered by Google and specifically used to cast an app, web page or browser tab. The capability of this setup depends on the power of your computer and the Wi-Fi. It is also the easiest way to do wireless mirroring from any nearby laptop.
It utilizes the Intel’s wireless technology and once you get up to sync, it is much simpler to use. You cannot use the laptop for some other work while you watch through it on the TV. It doesn’t use Wi-Fi Direct, but needs to open up a second Wi-Fi Connection. Overall, the video quality is good but occasionally some degradation can be seen.
Notifications
