A System Fan 90b Used To Cool Down Computer Heat
The system Fan90b is a system that cools down your computer when it gets hot, but it is not working. The system fan speed turns down, which should be stopped and removed from further harming your computer. You may shut down the computer and clean your exterior parts around the cooling area, which may be causing difficulty for the heat to come out. You can now reopen and check.
You can also upgrade the BIOS system which can help prevent the error from reoccurring. You also need to check all the wires, whether or not it is making noises, if you have old thermal and replace it with the new thermal compound. If even then it’s not working remove the thermal compound.
