ABBYY Fine Reader will be terminated
Hi
Please help. I believe I have done all the things correct, but it won't open with the licensing check disabled!
Here I find this:
ABBYY FineReader 11
ABBYY FineReader 11 will be terminated:
ABBYY Licensing Service is unavailable: The RPC server is unavailable.
ABBYY FineReader 11 Professional Edition
Please contact your system administrator to solve this problem.
OK
When I select 'OK', then the program shuts. I have completed what the readme said:
Quote
To cure the app either use file from Fix File Folder or use Patch "11.0.102.583.PE.exe". Copy file to C:Program FilesABBYY FineReader 11
If you get errors when saving results – disable licensing service or delete it by using the provided batch file "Del_Lic_Ser.bat".P.S. The file "Del_Lic_Ser.bat" deletes licensing service as it`s no longer needed.
NOTE: Now please help me. Only there is one file in the Fix folder named ''Awl.dll"… Is it correct?
Thanks in advance.
