Chad Brown
40 points
Posted on - 01/24/2013
Hi Expert, I would like to know if it is possible to load and then read pst on mac machines, on Android we can read, send and receive Outlook messages, but no way to archive them into .pst files, is this allowed on MAC ? that would be great if so. Thanks a lot.
Ability to read pst on Mac based system
Hello Chad Brown,
It will be possible reading PST on Mac if you follow some instructions that I have mentioned. I am recommending you to use this software of below link for Mac OS. Using this software you can read, send and receive .PST files on Mac OS.
http://www.littlemachines.com/
Or you can convert PST file and can read from your Mac OS by using PST converter. To download pst converter click here: http://www.pstconverterpro.com/
If you don not want to use outlook to read the PST file then you can use PST viewer software.
https://www.nucleustechnologies.com/pst-viewer.html
