G Racho
Posted on - 09/09/2016
Hi. I do have an IT background which is why I do not know about the latest software and technologies coming up. What are the steps required to carry out the 3com network director download? Please reply ASAP. Thanks in advance.
febi Joe
About 3com Network Director Downloadin A Few Simple Steps
Hi. Before we begin the 3com network director download, let us first understand the features of the software. It can discover as well as manage up to 1500 IP devices, rapidly solves problems, supports networks using many community strings, carries out alarm forwarding using e-mail, pager, SMSs, helps the administrator to configure the boundaries easily and enable the threshold alerts, generate reports on network topology, port capacity and many more. It also presents a network map, troubleshoots the connectivity by dashing the paths between two nodes on the network and connects to the web and updates itself automatically. Talking about its installation, before the installation of 3Com, the router manager and switch manager should be installed so that the installation of 3Com can create shortcuts to both these applications and others of its sort.
The installation can be carried out by inserting the CD in the ROM of the PC and then browse the CD. Next, the app needs to be clicked on twice. Then, follow the instructions which appear on-screen to proceed with the installation. After it is installed, you will have to activate it within a time span of 60 days. Next, activate the software by clicking on activate now so as to Launch the activation wizard. Click on next after entering the license key.
After this, retrieve the activation key and after you get it, enter it to get finished with the process of activation and proceed further.
Hope we helped.
