Hello Techyv Experts,
I need to know more about ASRock XFast RAM utility, Please do the needful for providing details about its working and the Technology used in it. Waiting to hear from experts, who has already used this utility,
Thanks in Advance,
George Saunders
About ASRock XFast RAM utility
Hello George
The ASRock XFast RAM utility software creates a virtual RAM Drive, and it allocates as much RAM as you want to use. Concrete, it turns it into a drive. That certain drive created, can be used for many things. Either if you use Photoshop, as a scratch disk or if you simply want it as a temporary drive. If you do photo-editing or you have a considerably large amount of RAM, it would be a very useful software to use, taking loads of your HDD.
I recommend this software, only to people who have excess amount of RAM, or they want to split their memory, using only 4 GB and dedicating 2-4 GB to something else.
The software has lots of facilities and options, but I would not recommend it to anyone who does not need it and just wants to see "What does this software do?"
I hope you found this information useful.
Randolph
