About conversion to gif quality loss problem.
I have a SWF file format and planning to convert in to gif. When everything was successfully done, I noticed that conversion to gif the quality was loss and does not meet my expectation for an animation. I need your help to configure this.
Answered By 590495 points N/A #143780
I’m not that good in creating animated GIFs but I know how to do it and I have already done numerous animated GIFs for my mobile site. Before complaining about the quality of the output file, you should check first if the source image or the original file is already in a good quality. You can’t expect a high quality result or output if the source is already not in a good quality. The output still depends on the source file.
You should also check the dimension of the source file from the output file. Their size or dimension should be the same to preserve the quality. Making the output file larger than the original or source file will decrease its quality.
