About Dell Service Tag Utility Download Using Simple Ways
Hi. I have recently purchased a Dell laptop. I want to download the Dell service tag utility but don’t know how to do it. What are the steps for the Dell service tag utility download? Please reply ASAP. Thanks in advance.
Answered By 150 points N/A #110220
Hi. The steps for the Dell service tag utility download will require you to find the drivers first from the selection page of Dell product and then download the device drivers by clicking on the option to download the file. Next, select the use download manager and click on continue. Read the terms and conditions stated in the license agreement and agree to them. Next, save the file to a location which can be memorised easily. The file will then begin to get downloaded. The download can be paused and stopped as well. To install the device drivers, click on install after the download gets over. Select open from the open files dialogue box. Next, select yes when asked if the changes should be made or not.
Next, confirm the name of the driver and click on continue after the application dialogue box appears. Click on the folder where the files should be unzipped and then click on OJ. Create a folder by selecting on yes and overwrite the folder by clicking on the yes to all option. After the files have successfully been unzipped, you will be shown a confirmation dialog box on which you need to select OK to close it. On the address bar of Windows Explorer, paste the address of the folder in which you had unzipped all the files and then press enter. Install the driver by clicking on the setup installation option twice. Allow the anti-virus to make changes to the computer by clicking on yes when asked. Follow the instructions appearing on the screen so as to successfully install the drivers and then start the computer again for the changes to be reflected.
Hope we helped.
