About Epson Printer Error Messages
Hey, I just turned on my printer and got an error message saying ‘Printing Error has occurred.’ Does anyone know about this Epson printer error message?
Hey there, I am sorry for you what you had to go through. It might happen due to some paper jam problem inside the printer. It might also happen in case if the cartridges are not fixed appropriately to its place. Follow these steps:
1. Ensure if the printer is properly connected to the CPU. Check for loose connections.
2. Check if there is any paper jam. Remove if any.
3. Try re-installing the cartridges.
4. Power off and restart your device again.
5. In case none of the techniques works, you can visit their ‘Contact Us’ here and get in touch with them. Hope that helps!
You usually get this error when you start the actual print. If you encounter this, check the USB cable connected to the USB port of the computer. Try to disconnect the cable and plug it back in. If this doesn’t work, try to uninstall and reinstall the printer software. Download the free version of Revo Uninstaller and install.
Once installed, start Revo then select your printer software among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the printer software back.
Try also updating the driver. You can download the latest driver software from the manufacturer’s website. See the following list of manufacturers:
