About an error sage crm undelete.
What will I do if I will encounter an error sage crm undelete? Give me some tips and your opinions about this. Is it also about compatibility reasons? My current operating system is windows 7 64 bit. Thank you
Hello Maxine,
You may be getting the sage crm undelete error message, and therefore you will need to troubleshoot. Since you are using Window 7 64 bit, you will need to ensure that the sage crm version that you're using is a 64 bit too. So just go to the internet, and then download the 64 bit version of sage crm, and the uninstall the one you have on the computer and then install the one you just downloaded. see if that resolves the issue.
Carl
