About HP Deskjet 5550 Installation Software In Simple Words
Hi. I am willing to install the software of HP Deskjet 5550. Can you please let me know the steps for installing the HP Deskjet 5550 installation software? Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #92555
Hi. To install the HP Deskjet 5550 installation software, first visit the website of Middle East drivers.html and log in using your credentials. If you do not have an account, sign up before logging in. Then, in the search box, type HP Deskjet 5550 and then press enter. All the search options matching with the words will appear on the screen. Then, from the list, select the OS for the HP Deskjet 5550 and click on next. Select the drivers which you will be needing and download them. All the downloaded files appear in downloads folder. The progress can be checked in the Google Chrome window. After the file is downloaded, click on the HP file twice to open the installer of HP so that the installation can begin. Some instructions will appear on the screen which needs to be followed so as to complete installing the drivers on the desktop. Hope we helped.
