About HP Officejet 6500A Plus E-All-In-One Printer E710.
Hi. I want to know the steps to print documents using HP Officejet 6500A Plus e-all-in-one printer E710N in Windows as well as Mac OS X. Please reply ASAP. Thanks in advance.
Hi. The steps to print using HP Officejet 6500A Plus e-all-in-one printer E710N in Windows require you to first load paper in the tray. Next, select the print option from the file menu.
Then, ensure that the printer which is to be used has been selected. The settings can be changed from the properties dialogue box of the printer. The print can be taken out simply in black and white as well by clicking the Advanced tab and then changing to the grayscale option. Next, click on OK and to start the print, click on OK. In Mac OS X, first, load paper in the tray. Next, select print from the file menu. Ensure that the printer that you have has been selected. Then, as per your requirement, change the settings of the printer. To begin with, the printing, click on print.
Hope we helped.
