About The HP Officejet H470 Ink Service Module In Few Steps
Hi. I need to replace the HP Officejet H470 ink service module, and I am not aware of the steps at all. Please help me with the steps if possible. Please reply ASAP. Thanks in advance.
Hi. The steps to install the HP Officejet H470 ink service module require you to remove the old service module as the first step by removing the power cord from the product, removing the battery and then finally removing the ink service module. Next, the ink service module can be rotated and then removed. Next, insert the new ink service module by removing the new ink from its package. Then, install the new service module.
Next, the counter needs to be reset by loading paper in the tray, reinstalling battery and plugging the power cord in the product once again. Then, press the power button so that it can be turned on. Then, print the test page so as to verify that the counter has been reset by pressing the power button and holding it. Next, click on the resume button while the power button is held four times following which the button should be released. Then, check the status value of the service module which must be 0.
Hope we helped.
