About ipad3 battery life enhancement
It is said that there are simple tweaks that can aid to provide enhanced battery life for your iPad. What are this ways to improve the battery life?
 Please make it sure dont make the battery charge to low .Never ever store the battery fully discharged.You can apply some charge before storage, and then charge fully before use.Do not overcharge iPad.Free iPad from its leather or any other case when charging the battery.You can  turn off Wi-Fi when you don't needed it, and/or adjust screen brightness.
Hi Stacy,
In order to increase the battery life, you can adjust different setting in iPad.
· When you are not using iPad, please lock your gadget.
· Wi-Fi and cellular networks can be turned off when you are not intending to you it.
· Location search applications will reduce the battery life.
· Trying to maintain Wi-Fi network or cellular data network will reduce battery
· Try to access data at specific intervals and limit the number of email accounts
· Screen brightness can be adjusted to help the battery life.
Hope this helps. Thanks!
