Ava larry
10 points
Posted on - 10/16/2012
Hello experts,
This is about Korean character support Nokia.
A Nokia mobile phone that possibly supports Korean characters, is there a software that can be downloaded in mobile phones to support Korean characters?
This is very important to me, I hope you can share with me your suggestions.
Thank you.
This is about korean character support nokia.
Hello Ava,
You can use the JLearnItME which is a multilingual translator for mobile phones.
This translator has got about 15 languages for 2 MB.
In the event that the word you want is not found, the closest words to it are shown.
It works on a mobile phone with Java, and it is freeware
Nicke
Dear Ava larry,
I have found a good result for Nokia mobile phones, this is a program called Hangeulider – Korean Keyboard 1.0.0.
This program represents a virtual Korean keyboard, it contains two input methods first standard Dubeolshik and the second is experimental phonetic.
But it works for Nokia mobile with an android operating system. You can download it from the link.
