About password reset disk on windows 7??
Asked By 110 points N/A Posted on -
I made password reset disk on windows 7. Will it work on windows xp?
Best Answer by metex
Answered By 5 points N/A #92657
Hi K Scatter,
Will your password reset disk working on windows XP?
Obviously NO for the answer, your disk won't work.
Your idea to have windows 7 disk to reset password really good, it is extremely useful when you forgot your password,
You can reset the login password with no time.
I know it was really scary to forget login password for windows especially when you have lots of important data stored.
Unfortunately in your case, it won't work, but there is a possibility it will work if you have dual-boot between windows 7 and
Windows 7 professional XP version.
I wish you all the best."
Answered By 5 points N/A #92658
Your Password Reset disk will not work one windows xp, as it made for windows 7, the xp will not detect this reset disk. You can make one more reset disk for xp.
Answered By 5 points N/A #92659
The Windows Password Recovery Tool is the answer to your question. This supports all kinds of Windows Operating system. You can purchase it for $17.95 and it can create a bootable USB and CD/DVD drive. It can reset your Windows local account and your domain passwords on your Windows PC. You do not need to type any command because it has GUI Interface so it is operable with just few clicks away.
