About PDF on My Mobile
Asked By 7060 points N/A Posted on -
Hi, I have been using this mobile for a long period of time. I have a question concerning the editing of PDF files. I have a class project that I wanted to edit some few things but it is in form of PDF. So I installed Adobe Acrobat, problem is whenever I try to open the document I get an error. My mobile phone PDF conversation does not work. Can anyone help?
Answered By 0 points N/A #199803
Hello Anonymous,
So basically you have a PDF file in your mobile and it is not able to open even after you have installed the Adobe Acrobat reader. You have not written the error message you received, so it is difficult to tell you specifically about the issue.Please try below.
  • Check weather this error comes only with your project file, download and other PDF files and try to open them. If other files are able to open the issue might lies with your file.
Below is the help link from adobe community.
Can't open PDF
Reply back with proper error message in case you're not able to solve with solutions given above.
–Scurlock Ward
