jaycepierce
10 points
Posted on - 08/25/2012
So far I have learnt here have been numerous programs that perform sending messages to cell phones and pagers.
SMS-Sendor also differs from them a large number of. I need to have a good SMS ActiveX or App. for VFP.Â
What's the best reliable way to go about sending SMS through VFP ?
ASAP
About the program Activex SMS vfp for Windows XP
You can find many software in Internet for sending messagesto cell phonesand pagers.
But the Logiccode GSM SMS ActiveX Dll v4.1 and the Kylix SMS .NET Component Version 6.2 seems to me better for this purpose.
Here the downlinks for those sequentially:
Hi Jaycepierce,
The good SMS ActiveX or App for VFP are as listed below:
1) Skebby:
a) It is the first application to send free SMS over the internet from iPhone or iPod touch to other smart phones.
b) It is a freeware software and the size is 3.7 MB
c) Download the software from the Skebby Official website
2) Freesms.net Symbian 1.28:
a) Freesms is a freeware application that allows to send SMS to all mobile phones
b) It allows to send flash SMS, group SMS, delayed SMS
c) It verifies the status of other mobile phones
d) Download it from the Freesms official website
3) Pop3 ActiveX component 1.0:
a) It is a freeware software which allows to send SMS to all phones
b) The size of the software file is 727 KB
c) You can use your login credentials for the system verification
