About reading dwg file for Mac
Hi everyone,
I am an architectural engineer, I have some plans in DWG format, and I would open on a Mac.
I am looking for a tool for reading DWG file for Mac.
Is there a possibility to open them on my Mac?
Thanks !
Best Answer by Mckenzie Birk
Answered By 5 points N/A #177033
Hi Carney
You can try this software ProgeCAD DWG Viewer available in Mac's app store.
But be advised that The interface of this software is very bad.
The presence of small icons in menus is not good at all.
But that is the best that can help you for the moment.
Hope it will help you to open your plans
Thank you
Answered By 0 points N/A #177035
Hi Carney Dale,
The most common tool being used by Civil Engineering, Mechanical Engineering, Electrical Engineering and Industrial Engineering as well as your program right now is the In-demand computer aided design software called AutoCAD.
This AutoCAD software is powered by AutoDesk which provides good quality performance and a larger requirements, This AutoCAD is also available for MAC OS.
