About The Steps To Uninstall HP Officejet 7310 All-In-One
Hi. I need to uninstall the HP Officejet 7310 all-in-oneurgently as I am facing a lot of problems with it. Please let me know its steps. Thanks in advance. Please reply ASAP.
Hi. The steps to HP Officejet 7310 all-in-oneinclude disconnecting the cable of the printer from the computer as the first step. It can be disconnected by removing the USB cable or the Ethernet cable. After this, insert the CD for the installation of the printer into the drive and then open it from my computer.
Next, click on uninstall so as to uninstall the printer. Open the control panel by clicking on start and then select control panel from the list of programs which appears. Select the more settings option followed by programs and features. From the list, select the HP Officejet 7310 all-in-one printer and then select the uninstall/change option for the successful removal of the program. Start the computer all over again.
Then, open the control panel and click on devices. Next, from the list of printers, delete the one with HP Officejet 7310 all-in-one written under it.
Hope we helped.
