thomastaw
Posted on - 07/29/2011
Hi!
Is it possible that admin can share the hardware configuration for the new server?Also, will it have the same settings as x5? That being max capacity of 5k online?
Last time you had a good start (first half a day, excluding the login server DDoS in first 2 hours) when server worked nicely. But after that we had a week of DDoS and shity playable conditions. Are you better prepared this time? DDoS attacks are bound to happen, it's given. We hope you are well prepared this time!
tuktuki
About Upcoming Server hardware configuration
Hello! Thomastaw,
You have selected the best services as your working process. The hardware configuration for new server works best level. You have to scan your whole system for a faster performance if you want to increase your server capacity.
It naturally works at the same process time will be expanding.
Thanks
Hi Thomastaw,
You cannot first of all share hardware configuration with your intended users.
Distributed Denial of Service (DDoS) or Denial of Service (DoS) attack is an attempt to make your network unavailable to intended users to whom the network is shared.
It temporarily or permanently interrupts or stops services of a host connected to the internet.
You have plenty of resolving solutions like Firewall protection, Switches with ACL capability, Routers, etc.
However, I advise you to download a Firewall protection from the search engine like Google to avoid such attacks and continue sharing your work more efficiently with the intended users.
No I don’t think so that you can share the configurations for a new server. To prevent DDoS attacks you should have a good security plan. And a fast server. There are lots of DDoS security Firewalls available on the internet which would protect you from most of those attacks.
You can find the best DDoS protection from here:
https://www.esecurityplanet.com/products/top-ddos-vendors.html
It will cost you some money but it’s worth the price. I hope this helped.
Peter Franklin
