I logged in to my computer and an error message saying: “ONENOTEM.EXE – System error: the appliance can not start because AppVIsvSubsystems32.dll is missing on your computer Try reinstalling the program. “Then I tried to start Word and get a corresponding error. I tried PowerPoint to start the same message. So I tried to see if the repair would work, but it did not work. How can I solve the problem?
Absence Of Appvisvsubsystems32 Dll
To solve this error you had to uninstall and then reinstall the MS office. Select the version you want to uninstall, and then click Next. Follow the rest of the screens and restart your PC when prompted. After restarting the PC, the uninstall tool reopens automatically to complete the last step of the uninstallation method. Follow the remaining instructions. Select the steps for the version of the workstation that you want to enter or generate.
