ACAD LT 2009 Silent Installation
Hi Friends, I am having a small clarification. I would like to know whether AutoCAD supports silent install without the interaction of a user.  Also do the needful for advising me on where to get ACAD LT 2009 Silent and how to do the installation. Waiting to hear from experts in this regard.
Answered By 0 points N/A #165148
Hi Sophiaa Price,
In order for you to a silent install for you Auto Cad LT, you have to use this switch syntax on your command prompt. The syntax is here: setup.exe /w /t /q setup.ini. To do this, you can open command prompt in few ways: one is by clicking start > run > type cmd and hit enter. Another one is by going to Start > accessories > system tools > command prompt and etc. Now that you are on your console now, Please change the driver directory by hitting C: D: E: or what every drive name you have and press enter. On your Drive name, where your AutoCAD is located too, you have to type the syntax above or here: setup.exe /w /t /q setup.ini and press enter.
