Is Access 2010 Ribbon portable?
Hi Experts
I am interested in knowing that if a Customized Ribbon is deployed in MS Access 2010, is it possible to take it to other PCs. I mean is Access 2010 Ribbon portable?
Hi Experts
You may use Ribbon Creator 2010 which is the best tool for creating custom ribbons. This is a WYSIWYG (What You See Is What You Get) interface for the development of ribbons and is simple and easy to use. Ribbon Creator 2010Â .NET Framework 2.0.
You can either use its shareware version but it will not provide all the functionality or can purchase a personalized license for $38
Or
You may deploy a customized Ribbon and Quick Access Toolbar in Office 2010. For more details click on this Link
Laz Zebbena
