anonymous
7060 points
Posted on - 08/10/2011
I can't access to my yahoo account and Gmail account.
Whenever I try I get a message saying that the server is unavailable, but yahoo.com and google.com both work fine.
NAV has found nothing and I tried to reset my hosts with the Hoster program, but to no purpose.
Can you help me out?
Access denied to yahoo & Gmail account
Please check your internet access speed. And also please check your connection whether it is connected or disconnected. Because sometimes it happens that the connection disconnects at the background and we are not aware of it. So check about that.
And also if it was disconnected and you click the connect now button and got connected, but still your browser says server unavailable then go to file menu at the top of browser left side, click it and options will appear. So, check whether there's tick marked on the "work offline" or not. If it is marked then re click on it and it'll be demarked. So now you can refresh the page or type a website on the address bar and the page will open.
If still the problem persists then I suggest you to test on different browser with the current browser. And also some areas of the house does not get network sometimes,
So please keep that in mind too.
