An access pin is being requested on Free Wi-Fi
Asked By 100 points N/A Posted on -
Why am I getting a message that says I need to enter the PIN for Cisco Small Business WAP4410N on SMN Free WAP?
If it's free there shouldn't be a PIN, should there?
How do I get past this block?
Software/Hardware used:
Intel Core 2 on Windows XP
Answered By 5 points N/A #96168
The network may be asking you for the WiFi Protected Setup (WPS) Personal Identification Number (PIN). This is a feature available in new routers that enables WiFi Protected Setup compliant devices to be able to connect to the network with minimal to no configuration required on the user’s or client’s side.
You can try asking for the Personal Identification Number from the owner of the network or from the network administrator and you also need to check if your wireless card and its software supports the feature. If not, then you can just ask the network administrator for basic network information like the SSID, network authentication, network encryption and the network key being used and just manually create the profile on your computer.
