An access pos database newbie
It is my first time to use access pos database, and I am trying to figure out how to input a number of items in just one customer and repeat the process with the others.
Can anybody help me with this?
Hi there,
The first thing you should do is to not tough the tables being set up on the forms. There are some calculated risks when messing around with the tables if you don't have experience in RDBMS environment.
The forms are there for the front-end operation. Look for the particular items in the drop-down list of your form and assign to a selected customers.
To repeat the process there is a ">" button on the lower end of the form which will take you to the next fill-out form which you may proceed to perform the same tasks as you did in the previous form.
