I have been using Skype on my machine running with Windows 7 for long.
Recently I have received an error regarding parameter. Have a look at the error message below.
I have no idea for the error.
Please help me to solve the problem.
Thanks in advance.
Skype
Access violation at address 012E5448 in module ‘Skype.exe’. Write of address 00000371.
An access violation error in WIN 7 happens when an application tries to use a specific RAM amount of your PC that was in use for another program. That's the simplest explanation about the error and this error happens due to a system crash. This error may common to any program that; in your case it's a crash in Skype application. This is a protection step within your computer more than an error message. You can fix the error by following the below instructions.
1. Try to download the latest updates for WIN 7 OS and install them.
2. Run a complete system scan from your Anti-virus program or use Windows Defender in order to clean the malware within your system if any.
3. If you receive the errors only with the Skype setup try installing a patch or update the program.
4. Run a registry scan to remove damage/corrupted files from your system. You can find a better registry cleaner software from the below site for free.
http://www.reggenie.net/lp1/
