Accessible software via VHD Test Drive Program
Using the VHD Test Drive Program, what other software that will be accessible on it? Can you tell me some?
What s up, Thaila,
That 's  a nice question over there that you have asked. The Virtual Hard Drives (VHD) can hold or be used with several programs or software such as Ms Office, Visual Studio, Antivirus software and several more.
Ensure all the other programs/soft wares can be accessible by the hard drives
It is usually made to work with other soft wares by just implementing it to be accessible to other features.
I hope this helps
Thanks
The VHD Test Drive program or Virtual Hard Disk is simply a file format that represents a virtual hard disk drive or HDD and is normally used as the hard drive of a virtual machine. It may have what usually is available in a physical hard drive like a file system as well as disk partitions which of course can have files and folders. This format is the usual file format used in virtualization that gives a consistent product support system. The file format was originally designed by Connectix and is intended for the product Connectix Virtual PC until it was acquired by Microsoft in 2003 for the now known Microsoft Virtual PC.
This VHD image format is made accessible to third parties since June of 2005 by Microsoft under the Microsoft Open Specification Promise. The only limitation of VHD format is that it can have a size of up to 2 TB maximum for any dynamic VHDs. And since you are asking about the kinds of programs that can access it, generally any programs or software can access it since it’s pretty similar to any ordinary hard drive only virtually and as long as you have a virtual machine to use it. If you want to download one, visit Run IT on Virtual Hard Disk.
