Accessing Pen drive that is blocked by admin.
In windows 7 Pen drive are disable by admin.Suppose there are two user one is admin another is normal user.now admin blocked the pen drive access Now how can normal can access that blocked pendrive.
There is practically no way that you can access that particular pen drive because of the restrictions that have been put by the administrator on that specific pen drive.
Before, there is a way if you don’t want others to use any USB flash drives on your machine by disabling the USB port right from the CPU’s BIOS. This will surely prevent others from accessing and using the USB port of your computer but gives a lot of work because you need to go back and access the BIOS again every time you want to use the USB port.
But if you don’t want to do this, you can disable the USB port of your computer by denying permission to these files:
The “%SystemRoot%” is the location where the “Windows” folder is installed, usually “C:Windows”. For the complete instructions to begin disabling the USB port, see How to prevent users from using USB? Another thing, the Inf folder is a hidden folder. To view this folder, enable the option Show hidden files and folders from your Windows Explorer’s Folder Options.
