Accidentally Wiped Hard Drive Mac Is Simple To Solve. Is It That Simple To Solve?
Hi, Everyone! I was facing a problem with the “accidentally wiped hard drive mac.”Is there a way to correct it?
A) To fix the “accidentally wiped hard drive mac” inside your PC, you will need to follow these steps:-
Step 1: Restart the Mac and press the Command button and the R key altogether while the startup disk is waking up.
Step 2: Now, choose the Restore from Time Machine Backup and press the Continue button.
Step 3: Choose your Time Machine Backup and press the continue button.
Step 4: Choose the latest backup of your Mac’s hard drive and press the continue button.
B) To fix the “accidentally wiped hard drive mac” inside your PC, you will need to follow these steps:-
1. Download and Install the SFWare Partition Recovery and then open it.
2. Now, choose the Recover Drive/Partition from the main screen options and then press on the drive to be recover. Now, hit on the Next button and choose the Drive/Partition recovery on the next page to recover Mac HD.
3. Now, double click and Preview the recovered erased hard drive Mac data and then save the files on your computer.
