Account Live Com 0x80072ee7 Error Solved Easily. Is It Solved?
The errors occur due to network, machine configuration, or software configuration issues. To rectify the “account live com 0x80072ee7; you will need to make sure that there are no emails inside the outbox folder of the Windows Live Mail account. As they go away when you re-configure your account or in Windows Live Mail or access your account using POP. To do that, follow these steps:-
1. Open the Windows Internet Explorer, then, in the Tools menu, go to Internet Options > Connections tab > LAN settings.
2. Now tap to clear the automatically detect settings check box.
To rectify the “account live com 0x80072ee7; you will need to follow these steps:-
1. Open the Windows Internet Explorer, then, in the Tools menu, go to Internet Options > Advanced > Security.
2. Now, ensure that the following checkboxes in the following manner:
“Clear the tick for server certificate revocation box,” “Select the Use SSL 2.0 check box”, and “Select the Use SSL 3.0 check box.”
3. Now, tap the OK button to close the window.
