Accounts Google Com’s Server IP Address Could Not Be Found
Hello, I wanted to accounts for Google com’s server IP address that could not be found an error. Please guide me in the proper way of doing it?
A) To fix this “accounts Google com’s server IP address could not be found” error for PC, you will need to follow these steps:-
1) Press on the Start menu button, write down cmd, and run it as admin.
2) Inside cmd write down these commands by executing one at a time and reboot after completion:
netshwinsock reset
netshintip reset
ipconfig /release
ipconfig /renew
ipconfig /flushdns
B) To fix this “accounts Google com’s server IP address could not be found” error for PC, you will need to click Start and type “troubleshoot,” then select the first result. Scroll down and choose Internet Connection. Run the troubleshooter
Notifications
