Active directory back draw or none benefits
What is Active Directory draw backs, none benefits, disadvantages or problems? I would like to know any information about such disadvantages of Active Directory. Thanks.
Active directory benefit:
1) In one point you can manage your network.
2) Active directory is very easy to use and install.
3) It is flexible one.
4) It gives high secure.
5) Control and administration are easy
6) It has the same data in all regions.
7) Active directory increase the user productivity.
8) IT administrations burdens are reduce.
9) Fault tolerance is increased, so downtime minimized.
10) We can manage millions of objects.
Active directory disadvantage or problem:
1) Network goes down when your active directory down. Active directory set up is easy, but once setup goes to wrong it takes a long time to remove.
2) It takes cost for infrastructure.
3) It needs good planning methods.
Notifications
