ACD Advanced Audio CD Player
Hello Friends, I have heard about ACD Advanced Audio CD Player. I would like to know whether it will work with my Windows XP and what are its special features compared to other similar Players. Please do the needful for providing expert input on this regard, as I am planning to have it in my Windows XP.
Best Answer by Marquez Abe
Answered By 0 points N/A #165296
Hi Rosellas Phillips,
That ACD Advance Audio CD Player is not quite good for it does not support many audio codecs that can run different audio file types. However, I would recommend you to use your own Windows Media Player embedded with CCCP or the Community Combined Codec Pack, it is a codec pack that can run all types of audio and video files.
Answered By 0 points N/A #165297
Hi there Rosellas, ACD or advanced analog cd player is a nice program for playing CDs and it is compatible also for windows xp. However, you might want to distinguish the ACD versions and its purposes such as the ACD basic which is good for just playing CDs, the ACD silver and Gold provides enhanced features such as converting the wma format to mp3 or mp4  to save storage space if you want to transfer the songs to your Hard Disk.
