Good day.
I want to add text to a JPG and a TIFF image using Acdsee Pro 3.
Are there available Acdsee Pro 3 add text tutorial which I could use for free?
If there's none, what are the step-by-step way to add text in Acdsee?
Acdsee Pro 3 Add Text to Image Free Tutorial
Follow below six simple steps to add text to your image(s):
1st Step: In Process mode and click Edit.
2nd Step: In the Add group, click Text. A text box will appear in the center of your image.
3rd Step: Click on Add Text pane and type a caption.
4th Step: In this step, you can adjust the font attributes and other text effects according to your needs.
5th Step: Now, Click and drag the text box to position it wherever you would like on your image.
6th Step: Do one of the following:
Either Click Apply to add the text to your image, and keep the Add Text tool open.
Or Click Done to add the text to your image, and return to Edit.
Hope, this would work for you.
In case if you require further help, please feel free to let us know.
Have a good day!
