Trevor Jhon
40 points
Posted on - 10/13/2012
Hello experts,
Acer 500 tablet video conversion compatibility. I just got an Acer 500 tablet and I want to perform a video conversion with so many format files such as mp4, avi and etc. I just want to know if what is the best converter which is compatible with tablets?
Thank you.
Trevor,
It seem's you are looking for an application for your android tablet to convert videos on them. If this is correct then I would advise you to download and install for the android market an application called Video Converter Android which is located on the Google Play store.Â
It's free and is one of the best video converters on the android market. Alternatively for a faster convert and better performance I would use a PC to convert the videos and then place them back onto your tablet.Â
You can do this through your USB cable that has come with your tablet. Once plugged into a computer you can use Windows Update to find the proper drivers if the tablet doesn't install them automatically.Â
Reason for using a computer to do this task is because a computer's processing power will convert videos at a much quicker pace than your tablet's processor. Thus in return you get the conversion done quickly and it saves you time. If you choose to go the PC route then use AVS Video Converter which can be found here:
For the Mac Operating System use Aimersoft Video Converter.
Since you are looking for a video converter that supports different file types or video formats and works with your tablet computer, then you may try visiting ImTOO. They have different Windows and Mac products. Like for Windows users, they have products like:
iPod/iPhone/iPad Tools:
iTransfer Platinum.
iPhone Contacts Transfer.
PodWorks Platinum.
iPad Mate Platinum.
iPhone Transfer Platinum.
iPhone Transfer Plus.
DVD/Blu Ray Tools:
DVD Ripper.
Blu-ray Ripper.
Blu-ray to MKV Converter.
Blu-ray Creator 2.
Video Tools:
Video Converter.
3D Movie Converter.
Photo Slideshow Maker.
Online Video Converter.
And for Mac OS X users, they have:
iTransfer Platinum for Mac.
iPad Mate Platinum for Mac.
PodWorks Platinum Mac.
iPhone Contacts Transfer Mac.
Audio Converter Pro Mac.
Video Editor 2 for Mac.
iPhone Ringtone Maker for Mac.
YouTube HD Video Converter Mac.
Just visit the website to download the converter you want.
