Acer Aspire 5532 Fan stop working
Asked By 400 points N/A Posted on -
TechyV Experts,
I am having a problem with my laptop's fan. My Operating System is Windows Vista. The model of my laptop is Acer Aspire 5532. It stopped working and I do not know how to fix it. I am kind of thrifty right now and as much as possible, I do not want to spend a cent. My laptop's fan would suddenly be put on a halt after 40 minutes or so that my laptop is turned on. Because of this, I decided to make my laptop rest for a while. But, the issue is going back. Please provide steps on how to fix this issue without spending too much.
Best Answer by paul info
Answered By 0 points N/A #112340
First you can use software’s to control you Laptop fan speed. This software can help in looking you laptop Temperature, and thus can control it also. So you can down load one of this software’s. The one is available at:
http://www.almico.com/sfdownload.php
It’s also free to download.
Secondly:
Dear what I am going to tell you is not a mystery, it is a simple way to check your Laptop fan.
First of all see where you laptop fan is located, in most laptops it is on the left side of the laptop under the keys, however when you find that do the following steps:
Turn off you Laptop.
Then take an air pump or you can just use a balloon for this purpose.
Now take the neck of the Pump to you Laptop fan are insert some pressure with it. It is simple and easy way. And your laptop fan will work correctly.
Answered By 0 points N/A #112341
Download SpeedFan software and run it, check your system fan information, RPM and heat temperature. May be its stuck. Try to fix it andIt’s difficult to fix in laptop here and get support from a genius mechanic. And remember again use laptop cooling pad for better cooling.
