Acer Aspire One Kav60 Driver.
Recently I installed OS for ACER ASPIRE KAV60. The OS works fine but some of the drivers are missing due to which system is not working properly. Does anyone have any idea to rectify the problem?
A driver provides a software interface to hardware devices. So for the proper working of your device, you need all the drivers to be installed properly. For ACER ASPIRE KAV60, you can easily download drivers form
https://www.acer.com/ac/en/US/content/drivers
All you need to keep in mind that the driver should be compatible with your system configuration.
You can choose compatible driver from https://www.acer.com/ac/en/US/content/drivers using your system serial number OR Product Model ( select netbook/chromebook-aspire one-AOD250).
Hope this will help.
According to Acer community website, the Acer Aspire KAV60 notebook is also known as “Acer Aspire One AOD250.” If you buy this notebook brand new, you should have the driver CD which contains all the drivers needed for your machine. But in case this disc is not included in the package, you can always download all the drivers from the Acer website.
Head down to Acer Aspire One AOD250 to download the drivers. Only three Microsoft Windows operating systems are supported by the drivers: Windows XP 32-bit, Windows XP 64-bit, and Windows 7 32-bit. The notebook doesn’t have a download for Microsoft Windows Vista in case you have this operating system. On the download page, just select your correct operating system from the dropdown list.
Just download all the drivers you need to make your notebook work properly.
