Acer Aspire V3 screen resolution
Acer Aspire V3 screen resolution is only 1366 x 768 despite being equipped with a Blu-ray spinner and Dolby Theater v4. Can I still get best color quality with this resolution?
Hy,
Acer Aspire V3 released few days ago and that is popular for the great feature and stylish look. This laptop has Ivy Bridge processor which is currently best processor from the Intel. Acer used that processor in their new product. So that’s an extra pleasure for Acer Aspire V3 users.Â
There have 15.6 inches monitor screen and the resolution of Acer Aspire V3
 Is 1366*786. That’s not bad screen configuration as a laptop. So there should have no any confusion about the display quality. If anybody can’t satisfy with this resolution quality then he/she would be waiting for next update from Acer.
Thanks
Here’s a little info on the Acer Aspire V3-772G-9460 laptop. The Acer Aspire V3-772G-9460 runs on Intel Core i7-4702MQ 2.2 GHz processor with 12 GB RAM, NVIDIA GeForce GTX 760M with 2 GB video RAM, 1.12 TB hard drive and solid state drive, Wi-Fi 802.11n (2.4 GHz only), and 1920 x 1080 pixels widescreen resolution. It has a built-in Intel HD Graphics 4600 second graphics adapter.
It is pre-installed with 64-bit Microsoft Windows 8. Standard battery rundown time is about 3 hours 48 minutes. For technical support, it is provided with 1 year warranty. For the pros, it has a full HD 17-inch display with Blu-ray optical drive and has both solid state drive and hard drive storage. For the cons, it is somewhat expensive with no touchscreen capability.
Some problems can be encountered with the touchpad gesture support. It has a short battery life and ships with lots of bloatware. If your screen is currently set to 1366 x 768 pixels, you can increase it to a maximum of 1920 x 1080.
