Acer intel pentium dual-core inside
My laptop is Acer Aspire dual-core.i just formatted my system due to some harsh viruses.I need a bluetooth drivers urgently.Can anyone help me out how i find original drivers and from where.i'll be waiting urgently.help me out
Best Answer by Veritile Phil
Answered By 0 points N/A #122744
Hi Billie,
Regarding to the driver of your laptop (Acer Aspire Dual-Core). I highly suggest that you should stick to officials sites of Acers. Because some sites might offer some wrong drivers and viruses. So I’m advising that you should check this site to download your drivers:
https://www.acer.com/ac/en/US/content/support
It’s the official support website of Acer where you can download you needed driver for your Bluetooth and you can check the other drivers too.
It offer the latest and the most compatible drivers and applications for your laptops and other Acer products.
I hope this solves something and have a good day.
Sincerely,
Veritile Phil
Answered By 0 points N/A #122747
Hello Billie,
I want to provide you a solution that may solve your problem. You can go to https://www.acer.com/worldwide/selection.html and there you can download your requested Bluetooth driver. On the other hand you can insert your motherboard disk to your PC. In the driver you can find Bluetooth driver software. Install the software. At this time the software is not working then restart your computer and try to run the software. I think this time your operation will be successful.
Thank you.
