shenna
Posted on - 05/20/2013
Hi, I've been using an Acer Travelmate P243 with a 2GB RAM. I have recently upgraded the RAM using Corsair Vengeance 8GB DDR3 1600 SODIMM which I bought from the local store. I followed a Wikihow step-by-step procedure on changing the RAM.
Right after the upgrade, I turned the unit on to check on the success of the RAM replacement. The display screen shows blue screen only. Help!?
Acer laptop won’t start after recent upgrade
Hello Shenna,
Don’t panic it will be ok again. I recommend you uninstall it and replace the previous one or an upgrade of it if you need a bigger ram. Read the specks or if possible go with it to the store so you can be given a similar one for acer or one which will be compatible. If you see a blue screen after installing the Corsair Vengeance, it means it is not compatible with your unit.
