Acer Liquid S100 fault finding codes
Asked By 35 points N/A Posted on -
Hello Techyv Guys,
I am in need of Acer Liquid S100 fault finding codes. I am using the Acer Liquid S100, sometimes my touch doesn't work properly. I want to calibrate my touch sensitivity. Can you guys please tell the codes to calibrate my mobile.
Thanks in Advance,
Luz M Terry
Answered By 0 points N/A #194060
To calibrate your screen setting please follow the steps below:-
1. Go to the phone's menu.
2. From there go to the settings.
3. Then select calibrate screen.
4. After that you will see some stars on the screen. Ouch them properly and your screen will be fully calibrated.
If you cannot even navigate to the setting for touch screen problems you should better contact the customer care.
