Jdonnel
30 points
Posted on - 03/22/2013
My Acer screen saver turns to blank display, I don’t want to change to windows screen saver because of its feature that is not present on other programs. I know that this is a pre-installed by manufacturer, is there any way to restore it?
Acer screen saver error – How to restore it
Hi Jdonnel,
Well,remember if you have a screen lock,remember that you cannot use or you cannot put your screensaver on your computer.You should start your screensaver with such a simple commands from your keyboard.Ensure that the computer registry settings are set to "enable" and not "disable" on the default login screensaver.To do this,go to the computer's registry editor by clicking "Start>Run>Regedit".Select the "ScreenSaveActive Enabled" value.Once this is done,exit the registry and reboot the computer.That's all i want to suggest to you.
