why is my Acer FT270HQL torch screen monitor not working? I recently purchase this Acer 22 inches torch screen monitor for use with my Window 8.1 operating system. The torch screen works in the first day but after that, it stop responding to torch. What prevent the torch screen from responding to torch? How can I fix this problem?
Acer torch screen monitor not working
If you want an ultimate touch screen experience using Windows 8. You should be using the Acer T232HL. Its ten-point touch screen technology and that provides a responsive screen for navigating Windows 8's interactive user interface, and it also offers rich colors and wide viewing angles that IPS. Or you may try a direct link to Acer support website. Drivers and Manual Section.
If that is a touch screen and the touch feature or function suddenly stops working, check if you installed the appropriate driver for your monitor. To download the driver again, go to Acer Drivers and Manuals. Here, enter your product’s model number or serial number then click to search for your product. When your product is located, click it to go to the download page.
On the next screen, it should detect your operating system. If a different operating system is displayed, click to change then select your correct operating system. Download and install all necessary drivers and software for your device. Note: download the driver on your computer to serve as backup. Computer manufacturers regularly remove drivers from their website for very old models.
