From the last couple of weeks, I am having a weird problem in my PC. Whenever I try to open the F: drive then something shows up saying, "Access Denied" or "Can't be accessible" the problem is all of a sudden and I have no idea what to do. Except for that drive all other partitions including C: are working fine! What is the cause of the problem? What can I do to stop it and prevent it from happening on future? Please, I want these questions to be fulfilled!
Acess Denied on one of the disk partition
Happy to support you!
Please follow the steps given under these 2 alternatives,
Solution 1 –
 Right click on your F drive > properties > security > advanced > owner > click on your user name or "administrator" >  select the "Replace owner on sub containers and objects" check box > ok > click "yes" on the security message that appears > reapply the settings for the drive & the content
Solution 2 –
Check whether the drive is displayed on disk management by following these steps,
Open control panel > system & maintenance > administrative tools > double-click "computer management" > enter the password if the drive is password protected > select "disk management" (in the Navigation pane, under Storage) > if there is no data in the partition, format it & check for accessibility.
Hope any of these solutions would be successful!
