I need an acme gamepad installer for PC. I am having controller problems. They will not work properly so I’m thinking I need a new installer to get the controllers to work properly. Can someone tell me where I can find a free installer for my PC?
Acme gamepad installer for pc
Dear Weary Edward,
Do not worry if controllers of an acme gamepad failed to work on your PC. The solution can be downloaded from the following links:-
1. http://www.2000shareware.com/info/ga-02gamepad/160821/. This software is supported by all the information you need.
2. http://www.2000shareware.com/info/ga-03-gamepad/112794/.
These Product features  are compatible with Windows 98SE / 2000 / ME / XP / VISTA / 7 TM
In case you install and the software doesn’t favor it again then change windows installed on your PC and try again, you will be successful. Good luck.
